Thanks for your replies. The cable needs to be extended about 10m, the same for the power cable too, as this will be used out of sight to open two large wooden trap doors high in a tower.
So a standard 3 core cable would be ok, that has Brown Blue and Earth, as long as the same connections are made at the top and bottom as to what is there at the moment?
How would I go about fitting a radio set to the system? Would that be expensive? Any benefits/negatives etc?
The other question I have is we also need the power supply to be changed, such that when we are away from the tower we can be sure no power at all is going up the tower, beyond the point of operation. In our inexperience the current plan was to extend the power cable to the hoist, and have this plugged in at the level of operation - hence it could be switched off and on with ease. Having done more research, and actually thought about it a bit more, a second option for this I guess would be to get an electrician to run a power supply up the tower which is switch controlled from the level at which it is operated. The winch could be connected to this, and hence only receive power when the lower switch was on. Would this be simple to do?
I also have another question - apologies if I shouldn't post it here... We also want a light system installed such that when both doors are closed, two red LED lights are illuminated at the level of operation, and when both the doors are open two green lights are illuminated. Again this system needs to have no power going to it when we are away. I assume the power supply could come from the new power supply our electrician could run up the tower, but my question is would it be simple to set up the system for LED indications for the doors positions?
Very grateful for any advice
