luckierPhil
Hi. I'm working on an old 11kV system with a mixture of old padmounts and ground mounted tx's. I need to know the fault current at one of the sites to enable a design of the earthing grid to proceed. I can get the fault level at the LV board using Fluke 1653. Do I just use the impedance of the TX (and obviously the turns ratio) to work out the HV fault level or is there another method?
