- Jun 21, 2008
- 17,017
- 43
What about swapping FCU for an IP rated one?
Oh dear , bit sick there , Slippers hate to be pedantic but she was hanged.Wasn't that Ruth Ellis last words :coat
Think 'beats electrocution' was a reference to her being hanged not electrocutedOh dear , bit sick there , Slippers hate to be pedantic but she was hanged.No electric chair in Britain.
Wasn't it Specs who got a job in a US prison and disconnected the chair because he thought it was a deathtrap ?
:C Ah yes ...I see what you mean now. It was Brian getting the wrong end of the stick, again.Think 'beats electrocution' was a reference to her being hanged not electrocuted
Only departures which do not result is a less satisfactory situation than compliance with the Regulations can be utilised. Departures cannot be used to note something which is less safe than compliance with the Regulations.you can note the test results of the ring and then note a departure for in-accessable connections(sockets)
I will do the second bit first...Not been on here for a while been very busy, hope every1 is ok.Got a couple of easy questions im unsure about,
half way through a mains change empty property
end to end on kitchen ring, L/L .45
N/N .16
normally i would try and find the fault and fix but every socket in the kitchen cannot be taken off as when tiled they have tiled the sockets in and there is no way of getting them off, is it my responsibility to fix this problem or should i just note on the cert?
There is also a boiler in the bathroom fed from a FCU, the fcu is roughly 1 m from edge of bath and under half a meter from sink, is it ok to leave as is or does it require to be ip rated?
thanks
Wouldn't he already have tested the one immediately before that one? :COR the point immediatly before that one on the circuit.
