hello Chaps few questions for you:
1. Changing switches or light fitting like for like or movement of a switch. Would i be right in thinking, You Would just do a Zs if metallic and no other tests, also no paperwork? would this also be correct for a replacement of a shower!
2. if you changed a light fitting in bathroom would it require rcd protection or is only when installing a new circuit.
3.Consumer unit changes would they require R1+R2 test or could you just zs
4. (periodic inspection) I have noticed in the onsite guide & the electricians guide that Either the (R1 +R2) or R2 method have a tick. Does this mean as long as a zs is carried out you dont have to record the continuity.
Cheers
Cheers
