justasparky
Hi there,
New to the forum so be kind. I have recently been given the task of inspecting and testing a large special needs school. I thought myself confident in my testing abilities until i started to question the readings obtained from final ring continuity testing. The readings at each socket should be approximately equal to 1/4 of the total resistance of both conductors. Now i understand that the readings obtained at each socket will be slighlty higher due to the contacts of the sockets and how tight the terminals are, but how much will the reading rise by which will indicate a connection loose enough to cause concern? I have removed sockets for further inspection and found nothing to be wrong, I have also discovered that with some of these new sockets the contact can have a small amount of dirt or something on them and require turning on and off again so that a good contact is made.
