Finding a CU / DB
NozSpark
Seaman stains™
May 28, 2008
12,329
141
North Wales Riviera
I need to find a CU for a job that I'll be doing it'll need to be quite a big one and is very probably non standard.....
The supply will be TT'd as it's a sub main from a TNCS
The building is a Granny Annex - living room, bedroom & en-suite and will be heated by fan assisted NSH's - hot water is a combination of solar panels and immersion heater - cooking will be a plug in 2 ring hob and microwave.
The supply is a single supply (no E7) however it is E7 at the house! they want to keep an existing SWA sub main (which is suitable)
Initially I was thinking of having a CU for the Daytime circuits & daytime supply to NSH's, a timer module and contactor in a separate enclosure supplying the E7 CU and circuits...
But it'll look a mess
So my newest idea is a double banked CU with the circuits as follows
Bank 1
MAIN SWITCH
RCBO - timer supply
RCD A
Bed & living skts
O/S lights
RCD B
Kitchenette skts
Immersion (horstmann timer)
Lights
Bank 2
RCD C
NSH 1 day tariff
NSH 2 day tariff
NSH 3 day tariff
TIMER MODULE
CONTACTOR 40A
RCD D
NSH 1 E7 tariff
NSH 2 E7 tariff
NSH 3 E7 tariff
Now that gives Bank 1 as 12 ways and bank 2 as 14 ways (not including any spares) - timer tales 1 way and contactor takes 3 ways
So I'm really looking at getting a double bank CU with 16 ways...
Does anyone know of any???
Seem to think any stacked boards I've used in the past have been all MK. Multiple row boards are quite European so you might have some joy looking towards Hager, and Legrand if you're into that sort of thing, maybe MG?.
MK looks like the way to go...
Just had a look at the Sentry pdf and it looks like they have everything I would need!
Will give their tech helpline a ring in the morning and get them to build me a parts list!
I fitted a pair of stacked MK boards on this job here...
(right-hand side of picture!Blushing)
http://i291.photobucket.com/albums/ll306/SPECIALLOCATION/PB120017.jpg
This job has 2 x 16way boards as follows:-
Top board
Main switch (incoming tails & isolates both boards) {occupying 2-ways}
2 x RCBO
1 x MCB
1 x RCD#1 {occupying 2-ways}
5 x MCB (protected by RCD#1)
2 x blank spaces
1 x Contactor
1 x Doorbell transformer.
Bottom board
1 x RCD#2 {occupying 2-ways}
5 x MCB (protected by RCD#2)
1 x RCD#3 {occupying 2-ways}
5 x MCB (protected by RCD#3)
2 x blank spaces (which will have a two module timer fitted in it soon!)
They look neat enough when closed for Domestic IMHO..
http://i291.photobucket.com/albums/ll306/SPECIALLOCATION/PB120018.jpg
I have used the MK stacking kits a few times.. no problems.
ElectricFix sell the 12 & 16 module CU's stacking gear.
HTH
:DGuinness
