fireman switch needed or not.
Status
Not open for further replies.
matt.leung
Feb 26, 2009
1,062
Bromley, Kent
Hi Guy's,
just want to run this past you to make sure that i am reading this correctly....
my boss as just asked me, does a firemans switch need to be put in place, if we are installing a neon sign, as a temp fixture in an exhibition. the circuit will be fed from a hard-power dimmer socket, and not left un-attended.
looking at Reg 537.6.1 - i would say no, but just want to double check before i look at total prat.
thanks.
he is not a spark, and wants my opinion though... i am still thinking no, but want to make sure i am reading the reg correctly... He likes to pick holes where ever he can...
Is the fireman's switch isolating discharge lighting?
Looks like it.
Is the exhibition within a building or outside one?
Could be either.
And if it is discharge lighting, why is it fed via a dimmer
switch?
Are you intending to mount this at the height stated in
the regs?
The unattended issue is possibly not relevant.
Slipshod may have a good point.
it is inside, it is fed from a hard power dimmer (entertainment dimmer pack - so not an issue),
It could be the exhibition centre asks for it ? Like they always insist on their own guys PA(T) testing at your expense anything you have brought on site.
Locked to prevent being resurrected (again)
Status
