Flat spot on back of conduit bends
Phoenix
Feb 14, 2010
1,149
224
Just a quick question, don't have much cause to get the bender out often, but have lately for my new workshop at home. Noticed that on the back of the bends I get a slight flat spot from the bend roller, not noticeable unless you are looking for it, but doesn't seem right but cant put my finger on whats wrong. Any ideas
is the roller actually rolling or like skidding across?
Try applying a little lube to the roller pivot (try WD initially to free it up and then some spray grease which won't dry out)
You could also try a smear of vaseline on the mating sufaces when in use.
Also try to bend in one smooth action - it helps the material 'flow'.
