Flickering LED light
Eric1066
Active member
Nov 1, 2022
28
3
Cyprus
I'm having an unusual problem that I can't figure out.
I have 2 identical LED light fittings in the Kitchen.
I have changed the light switches from a normal Rocker type to a wifi smart switch.
One of the lights works perfectly the other one is flickering.
I checked the connections and they are all tight.
I have neutrals.
Nothing else on that circuit, or any of the other circuits in the house, is flickering or having any problems.
When I put the rocker switch back on, the problem disappears.
It is a 2 gang switch, so I don't think there's a problem with the switch, as the other light works.
Writing this, im thinking of switching the cables around to check the switch, but i dont think that is the issue, so lets assume it isnt that, but I'll delete if it is.
The light fittings are 25w, so I thought maybe it was a low wattage problem, but like I said, the other one works, so.
Any help greatly appreciated!
Eric
Problem solved. It was the switch! I switched the cables around and the other one was now flickering.
Got a new switch and it all works!
