So had injector 4 replaced about 6 months ago as it was playing up. Same fault code occured 3 weeks ago. Multiple RAC visits and in the end had to take it to Fords.
Fords told me they had to plug it into their diagnostics machine at a cost of £95 because the 3 I had done by the RAC were not good enough apparently. Yep, they had the same fault code. Injector 4. Theybsaid that it needed to be reprogrammed. Total cost £250. Ok crack on.
One day the van lasted and the same problem again. Took it back to fords who had it for 2 weeks. Reset all the fault codes and said all was good and that theybtest drove it everyday for a week.
Lasted one morning. Same problem. They have now had the van for another two days and just told me all 4 injectors need replacing as it is a know fault that injectors with a certain part number are a dodgy batch!!!!!
"Ok great. When can you do it?" "We need to quote you first." "Why? Younsaid it was a dodgy batch!" "Yeah but they are out of warrenty."
So I am expecting a £1500 quote to arrive shortly to replace the injectors that were always faulty anyway. Already paid £250 to 'fix' the problem once and had no van for about 3 weeks.
