I hope someone can help me, i'm just trying to work out what might be possible.
The situation is that I have converted block of 10 flats, there is a main supply in, to 3 x 100 amp fuses, serving 3 different meters, this goes to 3 main fuses, and each supply is then split to 3, 3 and 4 flats, each fused to 63 amps. I pay the main supply, and have a private prepayment submeter on each flat, which collects the use of each flat.
The prepayment operator works on a % fee of each transaction, obviously as prices have gone up this has skyrocketed. As such I am wondering if it may be possible, and if so, what would need to be installed, to change the setup, to enable each flat to have their own main metered supply?
I realise this is likely to be expensive, I'm just wondering if it was possible to use the current main supply cable and just fit a box that splits it, or if they'd want to put new supply cables in?
Any help/advice anyone could give me would be much appreciatted.
