Now, i have just managed to get my new computer sorted, only took 6 days... Having a few problems with usb ports though..
On the back are three ports, 2 for the keyboard and mouse and a third one i have the printer in. On the front are 2 more but they are apparently "SS" ones???
Now, i plugged a usb memory stick in one of the front ones, worked perfect.
I plugged one of them "caddy"???? things into one of the front ones so i could connect up an old IDE drive with my data on. Worked perfect.
Plugged my camera into one of the front ones and the display on the camera flashed and the computer made beeping noises and could not find the camera properly.
Next i tried an external usb hard drive in one of the front ones. Light on the external drive flashed on and off at about one second intervals, and after about ten seconds the computer shut itself down, [in an orderly fashion mind] did not crash or anything.
I tried the external usb hard drive in one of the rear "ordinary" usb ports and it worked perfectly.
Tried the camera in a rear port, same thing happens.... [Does not work]
First question; What is happening here??
Second question; When I plugged the drive into the front port and the light flashed and the computer shut down, could i have caused any damage?? Why did it shut down??
Third question; How am i supposed to know what you can plug into what port as the ports themselves look identical apart from it says "SS" How are you supposed to know which devices can go in any port [like the memory stick] and which can only go in the rear "ordinary" ones, like usb hard drive......
Well confused...
john..
Well confused...
john..
