Hi.
I want to put three light fittings inside our three wardrobes (one in each).
I am going to put a switched fused spur fed by a single 2.5mm cable coming from a double socket in the bedroom which is a ring main.
I was going to feed each light fitting with 1mm cable.
My question is, can I run a separate 1mm twin earth cable to each fitting, therefore at the fused spur there will be
one 2.5mm feed in and three x 1mm twin earth cables coming out?
Or do I have to come out with one 1mm cable to the first light then loop to the second and on to the third?
There isn't going to be much room for two cables at each fitting
Thanks in advance for any help.
