gas solenoid shut off
sellers
Feb 2, 2009
2,582
-2
Got to wire 2 stops to a gas shut off solenoid. can these be powered off a local circuit? Or dedicated? Work is remedial after gas safety check, so no fire alarm link needed.
I would put them on the same circuit as the equipment that the gas is supplying is on. That way if the equipment suffers a fault and the CPD operates, then the gas is automatically cut off.
Do you think a locking stop button is enough? Or a contactor with a start button?
It depends what equipment the E stops are for.
For a boiler or furnace, I would use a contactor with start button.
For a kitchen, where the supply is for stoves I would suggest a locking button, that requires a key to be reset.
