- Feb 10, 2009
- 342
- 18
What method do you use to get cables up through the sole plate of an existing lathe & plaster/dry wall, causing minimal damage?
and a bit of PVC conduit to sleeve the drill so it doesn't rub the wall where you don't want it toF long drill bit on a F steep angle [and a couple of prayers doesn't go amiss sometimes!!]....... :coat
That's a VERY good tip, I must try that next time. I just rely on being careful, that doesn't always work.and a bit of PVC conduit to sleeve the drill so it doesn't rub the wall where you don't want it to
