Glue filled crimps
lilman
Jun 17, 2008
209
My stock of glue filled crimps is running low and I can't find a supplier - any ideas?
do you mean jelly (/silicone) crimps? they also have 3 way
(EDIT: stole a pic form ebay)
I buy mine from fleaBay.
Just searched under "heatshrink crimps" instead of "glue-filled crimps" and have found them on Fleabay. Good work Admin
Believe it or not, Electricfix do them.
Sorry to butt in on your thread but got question for pc. If your spurring off ring so 3 x 2.5 to crimp. What colour crimp do you use and do you heatshrink it all. ? Cheers
Not a good idea to use crimps for 3 x 2.5 as you would have to use a yellow which would be ok for 2 x2.5 and the other 1 x 2.5 would not crimp down very well better to use a red wago ideal for 3 x 2.5.
Its low temp solder, but some have additional rings of adhesive towards the ends to provide additional grip and some sealing of connection. I have some in van, and might go back to using them cos I don't like crimps, but crimps are quicker albeit crapper.
Thought you weren`t supposed to do this; or put 2 conductors into 1 end of a crimp?????KME
folding over is no different to a thicker conductor. 2 in one end could be a problem if not crimped correctly (i.e when its squashed, conductors sould be side by side, not top/bottom). but otherwise never had any problems (although i rarely have to crimp 2 into one side)
