Now I just want to check that nothing would trip an MCB downstream of the said breaker, ie only a fault on cct protected by MCB would cause it to trip?
Got abit of an odd case, whereby an MCB is tripping. Apart from afew issues with the grid anyway which DNO have now fixed, it also seems to have stopped since a fella who likes fixing cars a few doors up has moved, so suspect it may be linked to welding equipment, big dodgy angle grinder.
The said MCB is actually for a solar system, independently linked to a mini CU wired into meter tails. The CU for the house is not suffering tripping. My opinion is that the constant restarting of inverter caused by grid spikes is what is actually upsetting the MCB, but I would be interested if anyone else has come across a situation where something on the grid side of an MCB has caused tripping?
