GU10 led smd.... advice required
rugbymacc
Nov 27, 2008
322
Ok people
I have received a small quantity of these led (smd) bulbs from a supplier (all good)
The problem arises when you switch them on.
If you wave your hands around in the light being emitted. The actual movement of the hand becomes staggered (like a very small strobe effect)
The supplier thinks its down to an unstable voltage ????
I think it might be down to the full wave bridge recifier and the capacitor not doing its job properly ????
ANY IDEAS ???Pray
cheers
yep.
done that
just found this info explaining it all
Now, let
I have installed led lights and found them to flicker, even though the client did not notice.
This was down to the led driver, or transformer not being correct for the particular demand.
I have had to replace 60 gu 10's for led on one job, and all have been fine.
With no noticable flicker.
