Protective Device
As In ≥ Ib BS88 fuse In = 40amps
Correction Factors
Table 4C1, Cg = 0.57. Table 4B1 Ca = 0.87, as providing short circuit and overload we use Protective device rating in correction factor calculation.
It = 40 x 1/0.57 x 1/0.87 = 80.66 amps
Table 4E1A col 4 min CSA = 16mm2 with Ita = 100 amps
Voltage Drop
Column 3, Table 4E1B m/Va/m = 2.9 mOhm.m
(2.9 x 38 x 90)/1000 = 9.918 Volt
% VD = +9.92/230 = 4.313%
therfore VD is too high
Try next highest conductors, being 25mm2 having VD of 1.85m/V/a/m for (m/V/a/m)r, (mvam)x = 0.31 mῼ and (m/Va/m)z = 1.9mῼ
Taking advantage of Power factor for VD use √1-Cos20.8 = 0.6
thus vd = (((0.8x1.9) + (0.6 x 0.31))/1000)x38*90 = 5.83452 v
=5.83452/230*100 = 2.5367%
This does not meet the VD requirement so we can use the actual conductor temperatures to make a more accurate calculation
Ct = (230 + 90 - ((0.872 x 0.572) - (382/402))(90-30))/(230+90) = 0.88
Recalculation is given by
((0.8x1.9x0.88) + (0.6x0.31))/1000 x38x90 = 5.2volt = 2.26%
The cable does meet requirements of VD taking account conductor temp.
CPC sizing
Now we calculate CPC
Table 41.4 the max Zs that can be tolerated is 1.35 ῼ, thus max value of (R1+R2) is (1.35-0.8) = 0.55ῼ
Thus max value of (R1 +R2)/m is given by (0.55*1000)/90 = 6.1111mῼ/m m
Table 54.3 applies as the circuit is grouped with other circuuits Table 3.1 Col 6 for the R1/m for 25mm2 is 0.931 can be used with 3.94mῼ/m.
(R1 + R2) = ((0.931 + 3.94) x 90)/1000 = 0.43839 ῼ
Therefore the max R2/m that can be used is 5.17mῼ/m and therefore 6mm2
Zs = (0.8 + 0.44) = 1.24 ῼ
Thermal Protection
Earth Fault current Ief = 230/(0.8+.43839) = 185.73 amps
Appendix 3 the disconnection time is apprx. 4s and K = 143
a. K2S2 = 1432 x 62 = 736,164A2s
b. Ief2t = 185.732 x 4 s = 137982.5316 a2s
as a > b cpc is thermally protected
This circuit can use 25mm2 conductors with minimum CPC of 6mm2
Any errors/queries/comments, feel free to message/critisise etc, lol
---------- Post Auto-Merged at 12:04 ---------- Previous post was made at 11:35 ----------
Excellent - The students are setting questions now :slap @John - I hope you have the correct answer ROTFWL as there seems to be something in the question missing to enable it to be answered (Thanks Sidey - Think i have had too much Red !)
What's missing, everything is there to calculate, lol
