ivantw
Hello forum,
glad I found you. Not sure if I am in the right place or if anyone can help, but it doesn't hurt to ask right?
I'm fixing a short in my headphones and the ones I am using have a different wiring then I am used to so I wanted to see if anyone here would know the wiring or know how I can testthe connections before soldering.
There's a thicker all gold one - I know that's the ground.
THere are 2 solid thin green wires- that usually is left signal
There is a red and gold wrapped wire that is the same thinness as the green- Usually Red is the right signal
There is also a thin green and gold thin wrapped wire- that may be the mic or press play function that I have with my headphones, but I'm not sure.
Just for info, the headphones are ironman headphones I run with and they have a function midway up the wire that allows me to pause, play, volume and stop the headphones, so I am not sure which wire corresponds to those functions.
I tried soldering the red to right, all the green to the left and the ground, I got a stereo signal, but the vocals were dropped and it sounded as if I had some cross-talk since everything was "spacey" sounding, but I'm not sure if it's the wiring or not.
At any rate, even if you don't know the setup, is there a way that I can test the connections before soldering? Maybe with tape or something?
Thanks for any help.
-Ivan
-Ivan
