can any one help me please ,i need answer ;
1-give ONE possible reason for each of the following.
a) loss of supply to one floor of a multi-storey office block
B) cable insulation failure
c) RCD tripping on circuits which have passed an IR test
2-state
a) in the correct order, the first three dead tests to be carried out on a radial circuit
B) why the tests are carried out in a given order
3-
a) describe briefly how to carry out an insulation resistance test on a ring final circuit
consisting of socket outlets only
B) state the test voltage and the minimum acceptable insulation resistance value
4-an earth fault loop impedance test is to be carried out to confirm Ze.
State the reason for-
a) isolating the supply
B) disconnecting the earthing conductor
c) recording thr instrument serial number
help me guys my emil:[email protected]
Hello Dragon, I have moved these questions onto a new thread for you.
2-state
3-
