Baxi Combi 100 HE plus.
Hot tap water but no heating. Checked water pressure etc and pump appears to be running when hot tap is run.
I suspect the actuator valve is faulty it is a Honeywell VC4012 actuator.
How can I confirm this, and is it an easy DIY fix.
