Hi, please can anyone help me. Just moved into a new build where I have 2 lights in my front room both wired up to 1 switch. I decided I wanted to control both lights individually and thought it was as simple as buying a double switch. After buying a double switch I sort of worked out it's not possible. Today I took it upon myself to buy a dimmer switch instead thinking it's would be simple. Just opened up my switch and it's not as simple.
I have 3 earth wires joined together connected to the box. 2 brown wires in the 'com', 3 blue in the 'N Loop' and 1 brown wire in the 'L'. In the dimmer switch I have just bought (1 gang 2 way push), I have an earth, a x and L1 and L2. I know the best answer would be to get an electrician but I thought I'd try your expertise first. Any help would be gratefully appreciated. Thank you
