if the lighting circuit has a problem and trips off, then people tend to get it fixed PDQ, compared to simething like a dedicated smoke detector circuit
This anecdotal theory that customers get lights fixed quickly is in my experience often untrue.....
And having smokes off lights can bring greater risk of losing power to the smokes.
Also most lighting circuits need to be RCD protected....
Whereas its not too difficult to wire smokes without RCD's..
Lighting circuits are the one circuit that DIY’er tends to work on themselves more than any other...
fitting new lights they have bought from B&Q etc..
It’s not uncommon for them cock up some of the wires and lose power to part of the circuit, especially if circuit is looped at the fitting.
Then DIY bob who took the old light down is too proud to ask for help and keeps going for a few days or even a week+ before he admits defeat!
A fault I attended in June this year had 12 lights stopped working..
I asked when they had gone off,
Customer said..
Oh a couple of months ago… we have been using table lamps!!!!!!!
Good job their smokes weren’t supplied from those lights!
This is of course not forgetting that…
Mains powered smokes generally have battery back up!
A lot of smokes bleep once a minute if the power is off or their batteries are getting low!
Some smokes need you to unplug the mains connector to replace the 9v battery,
so probably safer for the DIYer to do with the circuit isolated, but that could mean turning off the lights in a dark hallway or landing where the smokes are fitted!
So there sill has to be an isolation point for the smokes FCU or similar..
What is there to stop this FCU being switch off without realising it but the lights still on?????
As a general rule a correctly installed circuit will not just randomly switch itself off so there is no reason for the smoke circuit not to remain on..
But what if the customer intentionally turns it off because of the old burnt toast bleeping ..?
Even if supplied by a light circuit they can be turned off and left off intentionally!!
If doing a rewire and a security alarm is also fitted, I tend to put smokes & security alarm off the same MCB, as the little key panel where they tap in their code normally has a light to say the power is on!
Jobs a goodun!
:Salute
