Are there any known problems connecting a large amount of high frequency light fittings to a RCD protected circuit ?
Exactly what is this ? Most of the fittings i am looking at are twin 5ft and have just one electronic ballast per 2 tubes and nothing else in the fitting.If there is a filter circuit on the ballast RCD will trip
Filter circuit will be incorporated within the ballast not seperateExactly what is this ? Most of the fittings i am looking at are twin 5ft and have just one electronic ballast per 2 tubes and nothing else in the fitting.I am referring to a commercial situation, but cant see what difference this makes (except wondering why anyone would want a large amount of fluorescents in their house)
i agree. it does seem oddHow's this for a conundrum.Hypothetical situation.
Situation 1.
Switch start flouro on its own circuit 5m from CU via switch.
HF flouro on its own cct 3m from CU via switch.
Situation 2.
Switch start flouro 10m from CU via switch, HF flouro 10m further on down came cct via same switch.
Sit 1 is allowed by manuf' even though there is only 8m between, sit 2 is not even though there is 10m between.
There is nothing in either cct to prevent any "backfeeding" is there.
Discuss?...
