It is TNS, not TT.
Submains are to each flat, not to each floor.Definitely not surface mounted, could be going through anything, havent investigated further, so buried.
Earth bonding all over the place in basement , ive not had anything apart yet to do any tests.Visual check that earth is in fact connected to main incoming cable, but nothing further.
5flats in total, plus the basement which is the landlord's.
Only 3 or 4 circuits to a flat(shower and/or cooker,ring final and lights), apart from Flat 1 which has 6 i think, back of cupboard and duff torch so might be 7.
Might be my mistake on the Time delay RCD, i can get my self confused, i thought i read that there should be protection on the cable from incomer to flat in event of earth fault if the cable wasnt SWA.Ill recheck on that, i was trying to read while wife and kiddy were distracting me.
**EDIT** the TD RCD was for discrimination if i read correctly and to provide protection for the submain to the flat. ...but i could be wrong
Landlord has told me the meter is being changed next thurs.
Not really sure of anything else i can tell you that would help.
itfr? unsure, checked acronyms but there are lots.
Off to double check my reading comprehension, ask away and ill try to answer.Back soon ish
