norv
- Feb 16, 2008
- 126
- 0
Just trying to suss out how to install some electric in the living area of a horse transporter lorry.
I was going to fit a CU for when they have mains hook up & have a couple of lights & sockets. I was also going to connect a battery charger from the CU to a 12V leisure battery so they could charge the battery from the 230V & use this when there was no hook up but they only want to use lights when there is no 230V available. I was then going to connect an inverter to this leisure battery.
How can I connect the 230V side of the inverter into the lighting circuit only, so there is one switch to switch the lights on or off regardless of whether they are on mains hook up or not ?
Cheers
Cheers
