- Dec 25, 2011
- 5,470
- 80
Anyone made one?
Looking to knock one up for cuttiing 1" thick polystyrene sheets to line a storage shed. Yes, I could use a saw / knife but it's messy and where's the fun in that?
Anyway, I've gotten some high resistance 0.30mm dia Kanthal wire from a mate who's into "vaping" apparently. (Not 100% sure if that's a legit pastime or not!) This is the ONLY wire I have so want to use it.
Resistance for the stuff is 20.11 Ohms/m. Thinking I can take a few strands of the stuff and twist together to make a "thicker" cutting wire. Using the wire in single strand form is firstly fragile and with too thin a wire the sheet will stick back together as it passes the wire. Most sites suggest using a variable power supply but I've a whole bunch of various fixed voltage, plugtop PSU's from various kit binned over the years.
Figuring I can maybe select a PSU from the collection and then make the cutting wire to the appropriate resistance (RT) from a bunch of the thin wires in parallel? For instance, 6 wires, 150mm long in parallel would give me an RT of 0.5 Ohms etc (as in 20.11x0.15=3.0165 Ohms, then 1/RT = 1/3.0165 x 6).
Try it I suppose.............and test it OUTSIDE! :lol:
