How To Fix A Live Neutral
Bachian
Mar 3, 2014
4
USA
I got a new guitar, plugged it in and got quite a buzz, from both the amp and guitar. Tested the guitar ground and all was good. I tested the AC outlet with a multimeter and got 54 volts from the neutral. Same reading on every outlet in the house. Can anyone explain how to fix this problem?
if you really are in USA, then your better looking at a USA based forum. our wiring is different from yours
but your problem is most likely a dodgy connection somewhere
54 v on the neutral....????
what sort of meter are you using?
and
where was you other meter lead?   on the earth / ground?
and
what voltage are you getting between live and neutral?
Could this not be an apparent voltage on the earth rather then the neutral?
i.e.
Earth/Ground open circuit somwhere..
apparent 50+v induced onto the earth...
If all your neutrals were at 50+ volts ..
most of you appliances would not be working as the live - neutral voltage would be effectively 54 volts less than what it should be.
Lose / bad earth could also give you buzzes and noises through your amplifier.
welcome..
Guinness
I was going to say that !!!
As Andy says , your system is different to the UK  .   You should have  110v  between the main poles  and if theres an earth (ground)  they would be , as PD says , 54v from each pole to ground .
Is it a 3 pin socket. ?
iirc america uses 110-0-110 split phase, so there shouldnt be 55v to anything
It's 3 prong outlets. Middle screw to ground reads .001. Middle screw and ground to neutral reads 54. All readings to hot read 110.
I'm using the:
v
on the multi-meter.
I get this bad reading on all outlets. How can I trace down the bad ground?
It would be awhile before I could afford that... Is it unsafe to play a guitar on those readings?
You need a US electrician  to be honest , we are not familiar with your system  although it may be that your N is no longer earthed  (grounded) .
Amps can be a nightmare if they are not grounded and at UK voltages can be lethal if the guitarist touches earth . Be careful  or go back to accoustic .
We would like to know what the problem was when you sort it .
