How to replace a 2 Gang 3 Way Switch
ed0906
Sep 22, 2021
2
I have a hallway that has 3 switches that control one light:
One downstairs which looks like a 2 Gang 3 Way Switch:
https://drive.google.com/file/d/1qh0p65ihNSbZuVfIubZmtnAXoGaNT3MH/view?usp=sharing
Another upstairs which looks like a 2 Gang 3 Way Switch:
https://drive.google.com/file/d/1GasKyZ67bjOLOXEvIADc5_NRjXqeQOuR/view?usp=sharing
Another upstairs which looks like a 1 Gang Intermediate Switch:
https://drive.google.com/file/d/1Y5WwBs6trSrO_vk2RVjORgQKkwdc8KGC/view?usp=sharing
I'm wanting to replace all three with more modern fittings, but I can't find any 2 Gang 3 Way switches on sites online.
Are these an old concept? The house was built in the late 80s so I wouldn't be surprised.
What type of switch would I buy to replace these?
Many thanks
2 gang 2 way is the terminology. No problem finding 2 gang 2 way decorative switches.
there is a bit less choice for intermediate decorative switches, so look at those before deciding the make of switch to choose.
Many thanks
Your images show 2-way switches..  (NOT 3-way switches)..
I think you are getting confused by the number of 'wires' to each switch..  not the number of 'ways' it can switch.
i.e.   A 1-way switch has TWO wires...
1x supply wire in and 1x switched supply out to a single load.  (1-way)
and a 2-way switch has THREE wires...
1x supply wire in and 2x switched supplies out, to swap the supply connection between one or two possible ways.   (2-ways)
{in your first image.. The red wire in L1 is swapped between the yellow wire L2 and blue wire L3, as you move the switch}
If you had a a 2-gang 3-way switch you would have 8 connections not 6.
as a 3-way switch would need 1x supply in and 3x switched outputs..   (4 terminals needed for 3-way).
[An intermediate switch will have 2 pairs or 2 terminals, (that are crossed over each time you operate the switch)  4 wire connections)..
The most important thing is want ProDave said...
A lot of manufactures have a limited range of intermediate switches, and/or,  some wholesalers / retailers don't stock the full range of available intermediate switches..
So 90%+ of the time it is much, much, much easier getting a 2-way switch to match the design of an intermediate switch...
Than trying to match an intermediate switch to the design of the 2-way switch!!!
Guinness
Guinness
Thank you so much for the help + explanation!
Calling a "2 way" a "3 way" is an American thing
just saying
Yeh these are UK switches :)
