identifying cables
avinalarf
Jun 2, 2008
415
what's the easiest way to identify cables within the consumer unit?
I ask because I came across a fuse supplying 2 ring mains and it was a bit of a nightmare when trying to test.
what's the easiest way to identify cables within the consumer unit? I ask because I came across a fuse supplying 2 ring mains and it was a bit of a nightmare when trying to test.
Depending upon room, when I have pairs of T&E ends of ring main, I will either strap the pairs together when they enter the CU.
Or put coloured tape or straps around the matching pairs.
I do also normally colour code me radials as well..
I have my own little "standard" I tend to use on re-wires for certain types of room so that I can remember what cables I have put where..
i.e.
Blue = Upstairs circuits {as in I "blew" up}
Red = Downstairs circuits {as in I "read" down the page}
White = kitchen & Util circuits {where the "white" good are}
Black = Cellar or loft circuits {cuz they are a bit "black" & dark}
Grey = Smoke detector circuit {smoke is "grey"!}
Green/Yellow = Garden/external circuits {gardens have all the earth in em!}
Yellow & Brown are spare for other one off circuits.?
so on a rewire I could typically have;
2x2.5 blue & 1x 1.5 blue (upstairs ring & lights)
2x2.5 red & 1x 1.5 red (downstairs ring & lights)
2x2.5 white (kitchen/util ring)
1x1.0 grey (smokes)
1x2.5 1x1.5 black Black (cellar radial & lights)
etc..
etc..
dunno if thats the sort of thing you mean?
or shall I get :coat
Depending upon room, when I have pairs of T&E ends of ring main, I will either strap the pairs together when they enter the CU.Or put coloured tape or straps around the matching pairs.
i.e.
1x1.0 grey (smokes)
etc..
etc..
what colours do you use on a radial supply a cctv circuit for a house :^O and also an alarm radial circuit Applaud Smiley
I have used something like this in the past: http://www.tlc-direct.co.uk/Products/CACMD.html
Good point:)Applaud Smiley
How well do they stay stuck on the cables?
Do you end up with a load of one number value not used much?
I certainly agree in a commercial installation you do need to go with some sort of Alpha-numeric idenification...
(I'd run out of colours! :^O :p )
you can also get those straps with a label area you can write on with perm marker.
But on domestic jobs PVC tape/straps can have sufficient combinations.
Good point:)Applaud SmileyHow well do they stay stuck on the cables?
They do stay on well. Used them more with UTP cables (esp when drawing more than a few at once).
You can use these to label the cables according to the mcb position. We did find the higher numbers were more likely to be left over and 0-3 got very well used.
Ian.
i.e.
1x1.0 grey (smokes)
etc..
etc..
IEE please note to include in the 18th edition :D
i.e.
1x1.0 grey (smokes)
etc..
etc..
for a re-wire, i normally have a note next to DB position with what circuit is to what numbered breaker, and 'cut' roman numerals into cable
Scratch on the Name of circuit with a nail/screw or smallest flat s/driver that I have to hane. :D
I have my own ident system where I cut into the cable with side cutters.
I have used markers but most will come off and get lost.
All industrial work is marked with cable markers and coloured clips.
As its sort of topical.. I got a picture!:DApplaud Smiley
A bunch of cables from the Stable conversion job I am doing, (first fix done, awaiting second fix.)
25 cables back down to CU!
(plus alarm & heating control cables to the left)
This is a bungalow,
An old original stable bit with "lounge/dine/Kitchen".
And a new build part making 'L' shaped property with "Bed1/Bed2/Bed3/Bathroom"
A did a different colour scheme on this one cuz no upstairs/cellar etc.. :(
I have also mixed multiple tape & strap combinations.
All carefully written down in my folder so when I go back I can remember what they all are.:pBlushing
Unless the builders been and peeled all me tape off! :( :eek:
