Hi!
I'm replacing the roof on my house, complete replacement all that's left right now is the walls, and I'm looking to mount some PV panels in among the tiles.
A simple task with many options, you would think. Oh no. The solar panel industry and the solar panel mount industry appear not to speak to each other.
To cut a very long story short, I've narrowed my options down to a GSE landscape frame with a JA solar panel. The panel has a width of 1722mm and GSE manufacture a 1720mm tray, in which it would probably fit just fine with a little persuasion. You can't seem to buy those for love nor money however, but the 1740 landscape mount seems easily available, GSE's documentation suggests that the narrowest panel I should really try and fit in this is a 1735mm, but I am wondering just how much an extra 6mm on each side really matters, when there seems to be a bit of fiddle room in the placement of the mounting brackets. I can't seem to find a panel that closer matches the size of the frame.
In summary - is it silly to try and put a 1722mm panel in a GSE 1740mm landscape frame?
Thanks!
Thanks!
