is it me or is that a 6mm cable on a 50A MCB?
Yup black and red in the top and the bottom of the RCD and 2 ground wires to the ground barAnd by the same token, if it's the feed it is not big enough either.
@CSW can you confirm there are in fact cables connected into both the top and the bottom terminals of that RCD?
It worries me I can only see one wire into one terminal of the earth bar. And nothing in the neutral bar.
And as the person connecting it clearly did not know what he was doing, I would worry he has the input into the wrong end, some makes of RCD get upset and let their smoke out if you do that.
Well I posted about the cable size prior to that BUT having looked at it again it may even be 4mm!!As it is I think the cable size is the least of the "OP's problems.
BTW, it's good to see you back
9.8kW rated showerWe'll, hard to tell from pic but, if that cable is the one going OUT to the shower it doesn't look large enough to be on a B50 MCB. I assume it's a 10kW shower?
Thats right , I thought he was a keen DIYer for some reason . As said , theres also a floating earth wire in the back . There could be a 40 / 50 A MCB in the board , who knows .It’s OK saying isolate first, where does a DIYer isolate safely? I know what I’d do but I’m not telling a DIYer due to the inherent dangers.
He needs a qualified electrician.
Now we have a mystery to solve ...........what is the real identity of Chewbacca ?Not been away Tony, just not had much to do on here recently, and I tend to post as myself and not as a moderator on the forum.
I think I know but I'm not saying . I remember Steptoe , I think , stumbling upon it .Now we have a mystery to solve ...........what is the real identity of Chewbacca ?
It's not me!Well,it ain't rocket science is it!
who hasn't been on here for a while?
who has A pair of consonants in his name?
who,used to fiddle with dogs and post pictures....AND he had a beard?
do I need to say anymore?
of course it's not you, you fiddle with cows :^OIt's not me!
Ah, back when I was a simple member I figured all the mods out. I took it as a little personal challenge.
