Inverter, Battery, PV earthing question.
Jan 24, 2024
37
12
Cheshire
My system has a Growatt SPH hybrid inverter and Growatt Li battery.
Both units have earthing points on their enclosure and both are classified as class 1 protection.
These are called out in the Growatt documentation which states should be fitted with 10mm2 earth cable.
My installer hasn't fitted anything to these earthing points.
Specific questions.
As they are both class 1 surely these should have earth straps to the enclosure?
Is there ANY reason for them to not be used?
Some UK/EU regulation I'm not aware of that states it's not required / shouldn't be done?
Anybody with same / similar equipment care to comment?
Internally an earth, from the property / utility supply comes in on the T&E AC cable to/from the inverter.
As far as I can see there's no earth to the battery. Don't know if any of the inter inverter / battery cables have 0v screens but that's not an earth.
As an aside there's what looks like a 4mm2 earth wire coming down from the panel array along with the DC cables.
This is joined to the property / utility earth at the AC isolator switch.
Assume this is an earth for the panel frames / mounts.
Just to draw a line under this one.
Installer has returned and fitted earth straps to the inverter and battery enclosures.
Response from Growatt regarding the battery was "its doubly insulated" ( something I'd picked up on in some other discussion on the web) so even though its class 1 the bonding strap is "optional".
Guess it depends on your jurisdiction / interpretation as to whether build trumps certification. :unsure:
There was no specific comment on the inverter however installer offered to return and fit to both.
