flyingspark
- Mar 3, 2009
- 48
- 0
I have just replaced an old fuse board with a dual rcd unit in my house, all ways have additional RCD protection.
The garage is supplied via 20A a radial circuit (installed 2.5mm t&e), cpc continuity, Zs and rcd opening times, etc are all fine.
The garage roof trusses are steel, and linked together by a steel frame, the steel does not extend down to the ground, the walls are solid pre fabricated 1950's type material.
House supply is TNS.
Is there a need to run a bond back to the MET in the house?
Thanks for reading.
Thanks for reading.
