Kewtech KT64 Pro Kit Includes:
Kewtech KT64 - The easiest, fastest and most reliable tester on the market.
Kewtech PAT Adaptor - PAT Test using your Multifunction Tester!
Kewtech JUMP LD1 - 4 Bright Yellow Jumper Leads
Kewtech R2 - The most sucessfull socket tester made
Kewtech Lightmate Kit 5 in 1 - The quickest way the test loop impedance
Kewtech R2FL - A New and innovative testing adaptor
Kewtech KT64 Multifunction Features:
The KT 64 is the latest multifunction to come onto the market and it makes ease of use it’s top priority with such features as a single rotary dial to select the required function, non trip loop circuits, slim probe with test button as well as a lockdown option on the instrument for the most convenient hands free testing.
As important as the functions is the overall packaging, the KT64 comes with a lid, convenient neck strap, a soft carry case with additional room to carry other tools for testing and the new robust Kewtech G7 test leads (fused and GS38 compliant). All designed to protect the instrument and make testing as easy as possible.
The KT64 caters for all the essential testing requirements of BS7671 (16th edition) in Industrial, commercial and domestic (part P) properties.
More KT64 Features:
Voltage Measurement
To save on having to carry an additional voltage detector the KT64 has a dedicated function for voltage detection.
Continuity Measurement
The test current exceeds 200mA required for BS7671 and range selection is automatic. Continuous testing can be carried out by use of the test button lockdown feature. A selectable buzzer gives instantaneous indication of continuity.
Easy to use lead null facility eliminates the test lead resistance from the results, the nulled value is retained even if the instrument is switched off.
Live circuit warnings are given by a flashing LED, buzzer and indication on the display.
Insulation Measurement
The KT64 has three selectable voltages, 250V for low voltage systems, 500V and 1000V. An auto- discharge function ensures that circuits are not hazardous after testing. A red LED gives warning of high voltage output during testing and discharging of the circuit.
In case of connecting to a live circuit, a live circuit warning is given by flashing LED, buzzer and indication on the display.
Loop Impedance Measurement
A patented low current loop impedance test current, enables high accuracy loop measurements and quick 7s testing.
A high current alternative is selectable for even higher accuracy and instantaneous results. This option is easily selectable and the subsequent test will default to the low current test, this saves any inadvertent tripping of the RCD.
Polarity indication, supply voltage and frequency values are constantly displayed.
The KT64 allows for phase to phase loop tests, again with an easily selectable option.
PSC / PFC Measurement
A separate dial position for PSC and PFC measurements with clearly marked selections makes this function easy and PSC can be taken after loop measurements without changing test leads. Again the function has low and high test current options with the default to low current to avoid inadvertent tripping of RCDs.
RCD Measurement
The KT64 has a comprehensive RCD test feature:
The KT64 comes with a full set of new ‘G7’ fused test leads. This includes a slim probe with test button incorporated which enables both hands to be free for testing. The G7 test leads have had a 21 point design criteria test which includes pull out and bending tests as a result they are very robust leads and come with overmould at the gripping points. They comply with GS38.
The instrument comes in a soft carry case which has extra room for testing accessories that the test engineer inevitable carries.
For added protection the KT64 comes with a lid with a quick reference guide attached to its inside and is supplied with an end of line calibration certificate which currently satisfies NICEIC / ECA requirements.
The display is of a fine pitch dot matrix type and as such is easy to read and has the ability to display multiple information, for instance all the autotest RCD results on one screen.
As you would expect from a Kewtech product the KT 64 meets all the national and international standards relevant for installation testing.
Bought 8th August 2012 so calibration date 8th August 2013. I can have this re-calibrated please contact for details
Only used a few times, new job overseas forces sale
Cash on collection from haywards heath west sussex or wilmslow cheshire
£450 + £20 postage royal mail special delivery with insurance
email [email protected] for any info
- Easy To Use
- No tripping loop impedance tests
- Test button in probe as well as lockdowntest button for ‘hands free’ testing
- Easy PFC & PSC measurementwithout the need to alter test probes
- Additional LED for warning of highvoltage output in insulation test mode
- Selectable touch voltage
- Backlit display
- Auto-test for RCD testing – single screen results
- Free calibration certificate included
More KT64 Features:
Voltage Measurement
RCD Measurement
- Suitable for RCDs rated at between10mA and 1A
- Tests at 0°and 180° phase angle
- Measures at ½ x, 1x and 5x nominal trip current with easily selectable options.
- Tests time delay RCDs (Selective) often found in TT systems
- Ramp test – identifies RCDs susceptible to nuisance tripping and identifies circuits with earth leakage problems.
- Auto-test – enables complete testing of a 30mA RCD (6 tests) while the operator simply stands by and resets the RCD. All the results are displayed on one screen – no need to scroll.
- Tests DC sensitive (type A) RCDs
- Touch current can be selected for 25V or 50V depending on application.
