jonathanwilcox
- Apr 1, 2018
- 2
- 0
Hi, guys, I have some questions regarding soldering:
why does my solder iron still have black stuff on the end after I wipe it on a wet sponge to clean?
what is the best soldering iron temperature to use on lead-free solder/lead solder? I'm also cautious of also overheating the wire (mine goes up to 350 degrees)
Is it better to have the soldering iron on a high heat for short time or medium lower heat for a longer time?
is it best to use lead solder with flux as some flux's don't have a high melting point causing char and oxidise? Alternatively, what is the right flux when working with lead-free solder?
how does charring reduce heat transfer?
Lastly, what size solder wire should I use for electronics?
If anyone could take time out of their Sunday to answer my annoying questions I would be forever grateful!
Cheers, Jonathan
Cheers, Jonathan
