Hi all, just hoping some one can please advise on some possible solutions.
I'm in the middle of renovating my property and have decided to have a suspended ceiling lighting frame built.
I need to now add the led strip lighting around the frame, I'll need about 7 meters to go around, RGBWW 24V is preferred choice, I believe that's the best performing.
The property has been totally rewired, so my question is what's the best way of wiring up the LED power supply/driver into the main lighting ring, it has to be a safe solution as will need to pass inspection etc.., also do I need to use 2 drivers to power 2 separate strips or can I just get a more powerful driver to power a single 7m strip.
Any suggestions for which products are good quality would be appreciated!
Many thanks in advance!
