level 3 practical exam guide
kajro0
Apr 28, 2009
5
SAFE INSOLLATION PROCEDURE
barrier tape area
select voltage indicator
verify voltage indicator with proven unit
turn off isolator
lock off insulator
keep key
test incoming tails
line - Neutral, Earth-Line, Earth- Neutral
VISUAL INSPECTION
check DB visual
check lighting circuit visual
take lamp holder cover off
check ring circuit visual
remove one socket cover
check motor circuit visual
remove starter cover
check commando socket visual
check RCD visual
remove Garage DB cover
check light circuit visual
check single socket visual
check Shower circuit
take cover off shower
check main bonding earth
check supplementary bonding - shake it baby
DEAD TESTS
CPC CONTINUITY TEST
select low resistance ohms meter
select 20 ohms
select auto null
auto null the tester
put temporary link into ET
remove line from circuit breaker situated on the left
put line into temporary link with ET
go to farer point of that circuit (lamp holder)
test between earth terminal and switching conductor
put value in R1 + R2 on test sheet
test switch is working and tick polarity on test sheet
remove temporary link and go to next circuit
take line of the next circuit and connect it to temporary link
measure between earth and functional line conductor
record the result
test switch and tick polarity
remove link and go to next circuit (commando socket)
put 16A plug into commando socket
test at connector block earth-line
operate switch and put R1+R2 result and tick polarity
go to motor circuit
measure between earth and line conductor
replace line back into circuit breaker
go to next circuit (garage RCD)
carry on R2 test only - test between ET's (don
Two things (There may be more), but these are common misconceptions:
..........go to next circuit (single socket)put line into temporary link with ET
test between line and earth by using plug socket
put down R1+R2 value and tick polarity
This won't confirm polarity on your single-socket circuit, even if you throw the switch..........you could have a Line - CPC swap.
RING CIRCUIT TEST
go to DB take out every circuit from ring circuit
separate legs of ring final circuit
test continuity of line - line, neutral-neutral, CPC-CPC
connect line of one leg with neutral of second
connect line of second with neutral of first - use connector blocks
test between connectors
use a test plug and check every socket between line and neutral
all socket must be switched on
take out neutrals and connect CPC's
test every sockets by using test plug between line and CPC
check polarity of socketsrecord highest value, tick polarity
put the covers back, left shower cover and motor cover open
No need to check polarity of sockets as 'polarity' is confirmed on completion of the three stages of the 'Ring Final' tests. ;)
Also I would press the test button on the rcd before I carry out tests because if the rcd is faulty your going to throw 150ma through the circuit causing a dangerous situation... Not good....Just how I would do it.
NO NO NO NO
the test button is the last RCD test you carry out.!!!!!!!!!!
---------- Post Auto-Merged at 21:04 ---------- Previous post was made at 21:03 ----------
BTW. how are you putting 150mA through any circuit?
the RCD is tested with NO loads connected.
Deffo agree with Steps here
RCD testing should be carried out in the following order (with circuits isolated) if it fails a single test then it should not be excercised until it passes
1x at 0 and then 180 deg
5x at 0 and then 180 deg
Ramp (if your tester has this function)
Manual - press the button
1/2x
Again, and I cannot stress this enough, DO NOT excercise the RCD to get it to pass any test,,,, in real life you will not get a second chance!
Revising this at the moment so glad to see it up in different words with a good debate behind certain steps, i've found a write up hereFault3 - Electrical inspection, testing & fault finding.and i've found a few problems with that. Can one of the more experienced members on here please tell me if this write up of procedure steps is accurate enough to use for my own revision? Thanks.
Yes I have the OSG in front of me now, i was just looking for a pre-typed up breakdown for the testing process. Although it's already in my OSg was looking for something a little easier to read. Cheers.
NL.
I would never recommend using descriptions from "other" websites to learn I&T because the C&G exams are quite specific with regard to their terminology.
