- Aug 3, 2009
- 1,807
- 272
Bit of advice please folks.
Domestic Garage/Workshop, has a lifting beam running between two walls in it, for taking engines out of cars, sits supported on the brickwork of the garage. There is 75 mm x 75 mm metal trunking passing close to it at one end (within 25mm). On the lifting beam there is a normal chainblock.
Should I put an earth bond onto this lifting beam. If the answer is no would that still be the case if the manual chainblock was swopped for an electric one?
Cheers Steve
Cheers Steve
