paul copeman
- Jul 11, 2011
- 54
- 0
hi all
i have a cct in a pub that trips after 2-3 hrs
breaker can be reset immediately and works fine for another 2-3 hrs then trips again
ive checked wiring at all lights on cct, disconnected lights and run IR tests on wiring
thought i found the problem when i pulled out a lamp and the screw cap stayed in its holder i.e glass broke off in my hand but problem still persists
trouble is it cct seems fine when i am on site and then trips after a couple of hrs
cct is supplying 7 bulkhead fittings 6 GU10 spotlight fitting (3 GU10 on each) and metal halide flood lights on a 6A breaker
which ithought wasa abit much so i removed some of the lamps from the spots and still problem persist
any help pls????
any help pls????
