EfficientEstimate
- Apr 13, 2021
- 1
- 0
Hi all,
I am trying to debug problem which I believe I caused . I am doing some paintings and wallpaper removal, so I removed some ceiling lights. Initially, as I disconnected the light plastic fitting from the ceiling, I interrupted the circuit, so I had no lights. I then reconnected wires and got the lights back. I continued removing other lights and now I am in a situation where when I switch on the light breaker; it trips immediately. To make a test, I interrupted the circuit again, disconnecting cables from one light (the same I knew I disconnected earlier on), but still it trips. I would have expected to see no trip and no light with a cut circuit, but apparently it's not.
Which is the best way to debug this problem? Can it be just because of a faulty connection I generated?
EE
EE
