Power Ball
I am a Part 'P' domestic electrician who just does a few odd jobs on a part time basis so don't have loads of experiance although compitent at the work I do, however a neighbour of mine has just moved house to a bungalow and after 1 week all accept 1 light has gone off. The wiring circuit for the bungalow is not what I have seen before. I have taken off 2 ceiling roses and pushed through a hole to the loft is a choc block.
3 single black cables (N)in one side
1 red Live in the other
Not seen it done like this before plus the red is perminant live and the 3 Black/Neutral are also live, when I split up the neutrals I can isolate the one that is live.
Can someone send me a diagram of how this circuit should be wired and any ides where I might start to look for the fault
I have isolated the lighting as he can use side lights plugged in for tonight
He assures me he has not touched any elecctrics since he moved in a week ago the light just went off !!
Living room 2 lights
Kitchen 2 lights 1 light still works ok
Other 4 Lights
By the way it's an old Wylex board with no RCD protection which he knows to get an upgrade a.s.a.p.
Chas
Other 4 Lights
Chas
