Hi, just wondering if anyone could offer some advice, occasionally my lights in the front and back room dim for about 2 seconds and then go back to normal probably happens once every couple of months. I've checked connections on the lights, switches and at the board all are tight and good connections. The front room has a dimmer switch and led gu10 bulbs, the back room light is a set of 5 lights that has a transformer built in and g4 halogen bulbs. Is this something that occasionally happens or does it require further investigation?Â
