Hello folks,
I have an issue in my property - flickering lights. These are lights on the lighting circuit, as well as lights (eg table lamps) on ring mains. Frequency is about one dimming dip every second or so, but variable. Often times, there is no noticeable flickering (maybe there's none). Other times it's quite intense - enough to trigger outdoor PIR-activated floods lights to permanently 'on'. This has occured during spells of dry days as well as wet days. No recent electrical work undertaken.
Switched 'off' the ring mains at consumer unit - lighting circuit lights still flicker. Switched off lighting circuit - table lamps still flicker.
Flickering of ceiling lights and table lamps is synchronous.
Had an electrician round to check it. He suspected fault in wiring may be causing sparking. He replaced the main switch in the CU. Flickering continues.
FYI, over the years (decades), we've have a couple of home improvements - extension and loft conversion. Each time a separate CU. So we have three - original plus two for new works.
Now, here's the puzzler. ALL lights - on all three CUs - flicker synchronously. If any two CUs are switched OFF, there flickering symptoms continue. It's does not matter which CUs are offed, the one that's on continues to have the symptoms.
So my thoughts are :
- is the issue meter- related? We still have old style meter with a ratating (4"?) horizontal disc and rolling numbers (like old style odometers in cars) .
- is the issue further upstream and related to incoming cables?
- could there be a general supply problem?
Any thoughts/suggestions welcome.
Cheers.
Cheers.
