Hello all,
So my TV signal has been terrible for the last couple of days.
I decided to check all the cables / connectors using a multimeter on continuity, making sure the shield isn't touching the copper core. They were all failing detecting a short.
I've traced it back into the lofts aerial and removed the cable tested it then and it was fine. So I put the cable back in and it's now shorting again.
I took the cable out again and tested the terminal that holds the copper core, cable clamp that holds the cable / shield, it's showing a short.
So probably a dumb question but before I buy a new areial, are these connectors in the attached photo meant to be connecting? My understanding is that having them touching would cause issues?
Any help would be much appreciated
Thanks!
Thanks!
