I wouldn't because they are not deep:O:Oif a loft is being boarded out for storage is it ok to drill through some of the joist for the cables. thanks
They do loft floor boards now that have compressed insulation on the bottom that can be layed across joists and is equiv to 130mm (so with 100mm from the existing joist height insulation gets close to the govt figures).A bit of knowledge a little off topic , the goverment recommendations for loft insulation have changed yet again from 4 inchs to 11 inchs !!! I say with some confidence this is much higher than all roof joists.Found this info when I appliedfor a job recently.
http://www.iglooinsulation.co.uk/loft_insulation.htmhttp://www.iglooinsulation.co.uk/loft_insulation.htm
Are cieling joists classed as rafters as I never believed they were?it is not advisable to cut or drill roof rafters without consulting either Manufacturer or a Structural engineer, unlike floor joists these are stressed in more than one plane, and need different load calculations.
Are you talking about a hand cut roof or pre made trusses, either way the timbers will be a lot smaller. It is unlikely you will find 8 x 2 or 10 x 2 timbers holding a roof up. The strength is in the design which is why you should seek professional advice before removing material from roof timbers.They do loft floor boards now that have compressed insulation on the bottom that can be layed across joists and is equiv to 130mm (so with 100mm from the existing joist height insulation gets close to the govt figures).Are cieling joists classed as rafters as I never believed they were?
I am refering to the cieling joists that the finished cieling for the room below is attached to not the trusses, rafters, purlins etc..Are you talking about a hand cut roof or pre made trusses, either way the timbers will be a lot smaller. It is unlikely you will find 8 x 2 or 10 x 2 timbers holding a roof up. The strength is in the design which is why you should seek professional advice before removing material from roof timbers.
http://farm4.static.flickr.com/3465/3241636882_f9d4592e28.jpgIf it is a modern build are those not part of the whole Truss as delivered ?I would hop up in loft and look but alas I have no loft as current accomadation is a flat roof. :coat
you can board out for light storageI was always under the impression that ceiling joists were there for one thing.To fasten the ceiling to and keep it held up.
Indeed. The structual part of the roof thats stops it 'splaying' is the collar tie in addition to being fixed to the wall plate.I was always under the impression that ceiling joists were there for one thing.To fasten the ceiling to and keep it held up.
I do not think that was being questioned, more that they are joists, not rafters and can be drilled. I would still not recomend doing that on a cieling you plan to put any weight on (i.e. stand) even if its not prohibited.you can board out for light storage
