Why would you bond to plastic when it is an insulator? :C :slapFitting main bonding before getting consumer unit changed.Have replumbed house using plastic from original brass stopcock onwards. Do I to still required bonding from here to CU?
Then it will need bondingMetal before stop cock and 500mm copper with Tee to outside tap on other side. Rest of system plastic
