Having an argument.Don't have the BRB or the OSG to hand.Can someone give me a reg number about TT earthing systems and the minimum earth cable size you can use on a spike.I reckon it's 6mm,but i always use 10mm.Thanks in advance
If this answers your question pg16 OSG fig2 states 6mm for Gas & Water, but does not specifically show CSA for the connection to the spike, but we might deduce not less than 6mm2 from the diagram provided, so if you prefer 10mm2 it's your callHaving an argument.Don't have the BRB or the OSG to hand.Can someone give me a reg number about TT earthing systems and the minimum earth cable size you can use on a spike.I reckon it's 6mm,but i always use 10mm.Thanks in advance
Quite correct patch that is EDF, anyway why would you not put a piece of 16mm in. Usually rod will be no more than a few metres from consumer unit so what are we talking aboutI'm sure we've had this beforeYou might not even need 6mm
One of the electricity companies won't connect anything less than 16mm even on TT
