- Nov 28, 2009
- 14,762
- 951
Okay so I have my panels, MY FIT is secure at 45p and it's working well.
I've educated Mrs PD so that the Washing machine, tumble dryer and dishwasher are only ever used in the daytime when the panels are generating, to use up as much as possible of our generated electricity. Of course only one machine on at a time.
But that still leaves a large part of a sunny day when the panels generate a lot more than we use. So being a tight git, I want to find a way to use more of our generated power usefully, rather than just let it go back to the grid.
So I'm thinking, whenever it's generating surplus power that we are not using, to "dump" the power somewhere.
I thought about just dumping it to a panel heater, but we don't need heat in the summer, so that's no good.
So the most sensible place to dump unused power is into our hot water tank. Use the surplus power to heat the hot water in the day, so not only will my panels give me income, hopefully eliminate any cost for electricity, they could also cut down our oil consumption. (oil boiler heats hot water normally)
So, I'll rarely have much more than 1KW, often less of surplus power. So I'm thinking use the standard 3KW immersion heater, fed via a 110V transformer, which back of fag packet calculations should be about 687W of power.
So what's needed is some current monitoring and some electronics, so that whenever generated power exceeds used power by 687W or more, close a contactor to power up the immersion heater via said 110V transformer.
I'm not saying I'm going to build this straight away, but I have the rough design for the electronics in my head. Before I start, has anyone tried anything similar? or indeed is there an off the shelf unit that you can buy to do what I want?
Or am I just bonkers?
